EGT to Can Module Update rate
what is the update rate for the egt to can module? I have scanned it using a can bus scanner and it shows 4 hz or every 250ms. I cant see any way to increase the update rate unlike the lambda to can module where you can specify a different rate in lite client. Are there any plans to increase the update rate with new firmware or give the option to be able to update the rate as 4hz just seems a little slow.
