EGT to CAN data stream into CANBUS
I managed to install the above device, I connected the can bus wires as depicted in the picture.
Now the EGT is connected on the software client and I can see the egt temperatures, however the adu data is now blank, when I disconnect the box from the plug the adu works, what I am doing wrong?
Probably can bus rate. Do you have errors on can bus?
Sorted, had 1mbps bus rate, changed to 500, and worked flawlessly.
How did you set it up on emu black
Guys please assist the same issue ver3 On the desktop cleint software i can see the egt’s on all 3 cylinders but how do i get the emu black to read the can egt messages .I tried everything .
