Hi everyone, But the +12V battery i can connect to battery disconnect switch or i can use the PMU output? Another question: the +12V switch connect to keyboard or not? Thanks for the help
you could connect the “+12V battery” to the battery disconnect switch.
“+12 Ignition” you could connect to the “ignition/switched supply output” from the PMU
Ok thanks guys for the support
