Hello there!
Im facing a problem with anti-lag system im using (Analog in#5).
from the settings in sensor setup
analog setup (Ain#5) is 4k7 Pulldown which means switch must be grounded. As give in help notes.
Mean while anti-lag doesn’t activate.
tps limit and arming cant be the same arming need to be lower than limit.
becouse you need to arm it for blipping throttle . als will be grean when is active this is not switch status
Oh! Okey now i get it, so its not arming status.
What should i do,
And what do you mean by blipping throttle.
And by the way im running DBW.
Kindly thank you!
If you are using grounded switch, you must use PullUp. And check if your analog 5 status is changing.
In the pullup is it mandatory to use +5 from ecu or i can use switched +12
U don’t need an external pullup…u can use internal pullup from the analog input…it can be set somewhere at sensorsetup.
