False KPA being sent on V3_043
Hi all Noticed that on the 0.43 update my CANtcu is receiving the wrong KPA values along with the calculated NM being Doubled. I have added some screenshots.
I’m traveling right now, I will check on Friday what is wrong.
Hi there Thank you, I also noticed that on the adu I was using ecu.map for boost reference and it looks like it reacts as TPS or something I can try and attach a video
The code for EMU stream was size optimised forthis versiob and probably it casued the issue.
Same issue being shown on a BTI display for me.
