Hi there all,
Regarding map sensor load kpa for vr6 3.6 engine is it reading correctly or something wrong i am new to ecu master ecus, kpa is 78kpa at full tps 3third gear pull.
Here what i understand the orange mark what’s actually reading purple marks should be reading 0 atmosphere pressure correct me if i am wrong?
If no restrictions in intake, it should be reading about 98-102kPa(you can also check the reading when engine is stopped, map should be about the same as baro). Check baro and map settings in Sensors and inputs.
Thanks sir i will check that.
Its emu black oem map sensor,
Baro is disabled.
whats the reading in idle? and whats it reading with just ignition turned on?
Its sorted out thank you sir.
I have a VR6 Golf 3.2 with the V3. I have starting problems…how did you solve it? Thanks
