- Under Drivetrain / Gearbox / Gear shift / Down shift / RPM Matching / RPM target / Source, can you add the ability to use a CAN channel (or basically any channel/user variable)? I’m running a BMW DCT with CAN TCU as the intermediary, and it sends a target RPM over CAN. I can always fake it by adding an Error channel (RPM - TargetRPM) to Project Tree and changing the axis on the Ignition Correction and Cylinder Cut base tables, but it’s cleaner to have it integrated the way you designed it to be.
- I’m on FW 226.x, and my CPU usage is quite high - 127%+. Max load 183%. Overruns is bouncing all over the place (which makes me think it’s increasing so fast it’s rolling over). PC1=17-20%, PC3=51%, PC11=31-35%, PC16=10-12%. The rest are negligible. Is it possible to increase the clockspeed on the MCU, or increase the optimization level? Or suggestions on what I should look at (granted this is while logging to USB, not connected to PC, so I have no idea how much it’d drop if I pulled the USB drive).
