I would like to kindly ask if you might consider the following for future development.
1, Where Classic gauges utilise less than 360°, could there be a function whereby the gauge background and highlight colours match the scale of the measurement scale? e.g. they also scale to 180° in the image below
2, Another request, currently it is not possible to rotate the gauges so that the pointer is vertically downwards. There are a number of road car dashes that have this layout and I feel it would add to the ability to replicate such designs.
3, A way to integrate gauges such as the Water Temp and the Fuel gauge above into other gauges. A new design for the gauges may be needed, however my suggestion below at 6 could be a possible solution.
4, The possibility to add ‘transparencies’ instead of colours on such items as the classic gauges. This would mean gauges could be overlaid onto a custom designed background, with elements of the design able to be seen through the gauges. Like the gradients on this display below.
5, Custom pointers for Classic gauges? Just some variants on the straight line type currently available.
6, And lastly, design ‘Layers’. So that effects such as the display above could be created by setting the RPM and Speedo on the layer above the Oil Pressure and Battery gauges.
I think the Ecumaster ADU is a fantastic product, and with a few additional improvements, it could become even better. I hope you find my suggestions helpful and constructive.
Thanks for your valuable ideas for ADU. We will think about a few of them and about the feasibility of their implementation. Maybe some of your requests will go to our to-do list for ADU, but you have to know that we have dozens of other tasks for ADU to finish. So, I can’t make any promises about if and when.
You can make a background skin that accomplishes most your demands, then just place needles or bars or whatever. ADU software is not for graphic design, you need to use as little of ADU memory as possible, a skin can do that.
I too would appreciate if you could share the best process for making a skin to add needles ECT, I’ve tired making skins with transparent backgrounds individual gauges and it seems to import way to big even if the image is compressed I’m using PNG files. I’ve tried removing background to then but transparency still seems to take up PX even know there is not colour there. See my image below is what I’m kind of looking for. Any help or a steer in the right direction would be greatly appreciated.
I find this statement a bit baffling as it is sold as an Advanced Display Unit. For me, Advanced and Display involves graphical design, especially considering fully addressable 800x480 LCD screen.
Check this example project, which is trying to mimic the page that you presented in the picture. It is built from simpler pictures, basic shapes etc. - you can check how it is built by studying the project.
