Page layout creation
New user, have only used ADU SW off-line.
Purchased an ADU 7, will be connected to MaxxxECU Pro, MaxxECCU PDM, a Blink Keypad as well as an CANChecked MFD32 display (hopefully… ).
Target is to have something similar to the BMW display, I have managed to get to the “screenshot” as can be seen…
Is it possible to get it more “look-a-like”?
How do I change the RPM graph to only display “thousand-values” (1, 2, 3 etc)?
Do not like the blue circle all around (on speedometer and RPM), would like to start at 0 and end at 200 resp 7500
The clock, I would like have it only displaying Hours:Minutes (no seconds)
The degree symbol (°) disappear on the cluster, why?
Temp gauge, would like to have “mirrored” (120 instead of 40 // 40 instead of 120) as well as with a needle and with more ticks between min/max values (as on the BMW screen)
Any help is much appreciated…
Just change the Min and Max values to 0 and 7 instead of 0 7000.
Unfortunately, I do not believe you can use transparency on the dials, otherwise you could have the background parts of the dial transparent over an image matching the original BMW type.
I also don’t think you can reverse all of the gauges (mirror) like you want, I think you can for the simple gauges like you’ve selected. Try setting the min and max opposite.
It’s a shame, as I think these features would give a lot more opportunities for designs. I’d also like to see the function of having a gauge upside down, so the needle points downwards.
See this similar post
