Fuel level refresh rate still high with 1Hz - what can be done?
I have a fuel level sender wired in to an analog of the ADU, the fuel level is playing around and its a bit distracting.
I have the refresh rate set at 1Hz, what else can be done in order to refresh it even less often like a timer or something like that???
Read the manual and use the fuel level strategy on adu. There is a perfectly working solution, and remember, the output is calculated ecu.fuellevel
Thx, for the suggestion. I read it long time ago and most forgot it.
For anyone looking for an evident answer:
  1. Define the Analog input
  2. In CONFIGURATION tab >> Fuel Level Filter define the configured Analog Input and configure the desired refresh parameters.
  3. On the screen the source channel where the filter output comes will be ecu.fuelLevel
Is there a way to display the level in litres rather that percentage?
Use a number element or table to calculate litres from a percentage.
