GPS find no fix
my gps work Great, laptimes and predictive laptiming work Perfect.
But now, i cant find Track and in light Client it Shows no fix.
And ideas?
FW17.4
Seems like an issue with the antenna.
Check it visually.
Inspect if the cable is intact.
Make sure the antenna connector is tight.
Finger tight is usually not enough.
Use an 8 mm wrench and screw it a bit more than finger-tight.
Actually we Drive With 2 Cars and on my usb Stick on Both Cars, i have Full gps data and Timed laps , but on screen, while driving, there is no Time shown? Any ideas ?
I think, we have the problem, the start circle is to little, can I change it?
Could you share your ADU project and ADU log from the track where this issue occurred?
