Hello, help me arrange the functions because in version 2… I had them set to virtual output, mainly the momentary switch. It is connected to the CANswitch Board under CAN1. In the same position as in the first photo.
Where MS1_A is the off state, MS1_B is the virtual output from the CANSwitch Board (and after CAN on the ADU defined by the CAN stream and has an alarm set), MS1_C is a change in the throttle characteristics.
But now to the point, in ver. 2.xxx there is MS1_A etc.
But in ver. 3.xxx LSW_A, there are three states as in version 2.xxx but in the functions I do not see the individual states to set a rule for them.
I will only add that the output from the virtual ouput goes further along a defined CAN stream to the ADU and from the ADU after AUX1 I send the voltage to the RACE TCS through the table to set preset 7 where traction is turned off.
For those who are not aware, I control the RACE TCS via a rotary encoder and settings in the EMU and I have all the information from RACE (i.e. the flashing diode) already displayed in the ADU and what preset I am currently on.
how to set the output to CAN only on one state of the momentary switch output
