I’m just started to use PMU24. I want to measure different sensors which has a 0-12v output signal. I planned to wire them to A9-A16 analog inputs, but the maximal value is 5v in the Ecumaster software. How can I set them 12v to max value?
thanks for your help
You are right, there should be an option to input higher voltage values for those inputs.
We will have to update that.
For now, you can use the table to configure the sensor.
It allows higher voltage on the axis.
Is it an actual sensor or just a switch from 12V?
If it is a sensor, can it maintain a stable reading despite changes in battery voltage?
Ok, thanks, i’ll check it soon.
It is an actual sensor, but it has a 12/24v converter, so it has a stable output.
thank you again
