Hello everyone, i’m marco with my subaru impreza my99 and try with mac3 or pierburg solenoide. I can’t figure out what I’m doing wrong. Even when I set the DC feedback table to 0% or 10%, the turbo pressure skyrockets. When the engine is at rest, the turbo is connected to the wastegate, but once I start driving, it’s as if the wastegate remains 100% closed. I tried setting the output to “inverted,” but then the wastegate stays open all the time, leaving me with only the base (spring) pressure. I’ve tried using both a MAC3 solenoid and the original Pierburg solenoid from a Golf TFSI, but I still can’t regulate the turbo pressure—it’s either at the minimum level or completely out of control. I’ve attached my project file and a log, which I hope I’ve captured correctly.
Mate you havent set a boost solenoid output.
Also you havent fixed your boost target to Valve DC Feedback table at all… While you have found out how to enable rotating Idle for show off, while you have 9.9AFR at 0.5bar of boost.
Thats as Rookie a mistake as someone can make, you might want to start with V2 software first
Turn OFF PID first, Stop all of you enabling PID and expect the pid to resolve everything by itself…
Second fix your AFR no1 before raising any boost.
Make your Boost - DutyCycleFeedback working without any PID.
If you make everything nice, you might not even need to turn on PID, or set it to a very low correction, because PID needs to be setup correclty and i dont see you having the knowledge to do it correctly
