how can I setup the injector flow using a table with injector pressure differential as axis? I can only find the option for reference flow using a fixed value
regards
Injector flow for pressures different than the reference is calculated automatically.
Injector pressure differential is used for that calculation.
The result is in the corrected injector flow channel.
