Injector phase for 4cyl only crank sensor
Hey,
im Realy desperate and need your help. i dont understand injector phase degree
Car is 2.0 16v Turbo firing order 1342
only crank sensor
dual coilpack
cylinder 1 and 4 are coil1
cylinder 2 and 3 are coil 2
can somebody please tell me the settings for ignition and injector phase to make it work im realy struggeling
i use v2 and v3 software, so it doesnt matter please just tell me how, car always got wet sparkplugs and bangs at exhaust
i use trigger settings from old kms ecu that was installed bevore.
car runs one time,but i cant find the right settings anymore.
amd maybe what fuel settings for porsche 630 injectors.
please help me out i tried everything, engine is brand new and is tart killing it whit fuel flooding…
very best regards
lancia_base_stefan_v1.emub3 (62.0 KB)
There is major difference between v2 and v3 software in terms of setup
how have you wired your injectors?
Is:
injector 1 from Cylinder 1
Injector 2 from Cylinder 2
Injector 3 from Cylinder 3
Injector 4 from Cylinder 4
because from the table below the Injector 4 is set to Cylinder 2 and Injector 2 in cylinder 3 and injector 3 in cylinder 4…
could you also please attach a log file and scope log.
Please stick to one firmware version either v2 or v3. then it is possible to get somewhere with the issue.
