Fused +12 V to G8/G16 measures about 12 V with a multimeter.
My concern is whether it is safe to connect the passive ignition coils in this condition.
If there is always about 12 V between the fused +12 V line and the ignition output pins, does that mean current will continuously flow through the coils and possibly burn them out? Or is this normal behavior for low-side ignition outputs when the coils are not connected?
I want to confirm this before plugging in the coils.
Connect a coil and measure the current flowing through the circuit. Being a passive coil, it should be fine being connected for a few seconds while you take a measurement.
An alternative (and good for testing) would be to connect a 10W, 10 Ohm resistor and connect that up instead of the coil.
What current reading should I look for to confirm the transistor is shorted? At what point does it go from ‘normal phantom voltage/leakage’ to ‘faulty continuous ground’?
Im gonna assume you have the ign outs set up to drive passive right?
Is this CLASSIC or BLACK?
BLACK has built-in circuit protection for cases where incorrect coil type has been selected, CLASSIC does not.
You clearly have a good understanding of circuit testing. What is your reason for doing these tests? Do you suspect you have cooked the board somehow already?
It is an EMU Black, and I am using the V2 software.
The engine has previously started and run smoothly with this map, so the basic map/configuration had been working before.
But at some point it stopped working. During diagnosis, I removed the spark plug and checked for spark visually while cranking, but there was no spark.
That is why I am now investigating multiple possible causes, including configuration, wiring, coil, and possible ignition output/driver issues.
