Ignition output- spark distribution
Hi, from the resources online and in the manual, i dont see any info on the DLI settings.
I have a bosch 0211503407 2x2 coil, connected to 4 sparks via HT ignition leeds. The 3 pin connector on the coil is connected to the ecu as follows,
  • pin 1, ign4
  • pin2 12v power
  • Pin3 ign6
I have measured the coil and its resistance is ok, the ecu outputs have been tested and they are ok. How come i dont have any spark? Thx
How is the ecu configured, for an internal ignitor or external?
Is the ECU and coil grounded to the same point (probably should be the head)
I had t configured for Coil-> Wo external amp
The coil is grounded by the ecu from ign 4 and ign6 pins from the documentations, there are no other grounding points specified
I found a data sheet for this coil, part number is 0 221 503 407
Sounds like you have the coil type setting correct, I would like to see your configuration of the ignition outputs. This however would not affect an output test and It’s my understanding you are not getting spark during a test either?
I’d make sure there’s 12V at the coil when testing.
I’d also try mounting the coil (or grounding the mounting points) to the engine just in case.
