Has anyone put together a wiring pinout to convert a honda k24 harness to the emu classic?
I’ve pinned out a 1JZ harness to the EMU Black before and all that was super straight forward and understandable for me. But now that I’m looking a k24a1 pinout and I can’t make sense of it and not sure at all how to correctly pin it to my emu classic ecu.
I’m hoping someone else is running a k24 and has a pinout already figured out that can clearly tell me k24 pin A(x) / C(x) / E(x) to EMU Black(x) / Grey(x). Because I can’t make sense of the k24 factory pinouts and dont want to fuck up my engine or ecu.
Thanks, and sorry for being dumb on this lol. Ive searched the webs for hours and have found nothing that helps.
UPDATE - I was finally able to figure out most of the harness pinout into the EMU Classic. Now my only struggle is understanding all the VTEC Wiring. Ive done research on other forums and everyone is talking about high sides, low sides, or they can be either. I dont understand any of that at all.
I’m mainly needing help understanding how to wire up the following -
VTC Oil Control +VE - wired to 12v maybe?
VTC Oil Control -VE - wired to AUX 1 maybe?
VTEC Solenoid High Side - wired to 12v maybe?
Thanks!
Are you able to send the pinout
I run a K24 with Ecumaster black and Pro but the wiring is the same as for yours
VTC Oil Control +VE - wired to 12v fused
VTC Oil Control -VE - wired to AUX (you pick which one)
VTEC Solenoid High Side +VE - wired to 12v fused (same as VTC)
VTEC Solenoid low side -VE - wired to AUX (you pick which one)
Please also be aware that unlike most crank and cam sensors the K24 uses +12v not +5v, and the crank wiring is actually different to the cam ones and not the same as the K20.
