Good morning, is there a way to deactivate the knock detection during flat gear shifting?
Knock ia always disabled when the spark or fuel cut is present.
Ao it should be disable during flat shift. Do you have any particular problem with that ?
In my logs it doesn’t seem to turn off, voltaje spikes are detected on the knock sensor during gear shifting
reading is there i think but no action for retard and enrichment happening
You will see the spike as the knock system works all the time processing data from sensor.
What is important for you is knock action.
Make sure the parameter Fuel / Cut spark delay is set to 300-500ms.
Then in the case of fuel / spark cut disable knock action for above time, prevent system of retarding the ignition.
Thank you very much, I had it in 0ms
I will change default value to 250ms
