Hi everyone,
I’m asking for help with an issue I’ve been dealing with for a long time and haven’t been able to resolve. The car is an Audi TT MK1 with an APY engine, various track day modifications, running on E85 fuel, and using an ECUMaster Black ECU.
The engine is semi-new and was remapped in December 2021. In February 2022, after the initial break-in period, it was used for some track testing. In the days following, while reviewing the logs, I noticed that from minute 51:35 onward, the car started detecting knock almost continuously, while the values were correct in the first part of the recording.
After that session, due to personal health issues, the car was left unused for two years. I picked it back up a few months ago (there should still be an old post from me about this same issue), and the car is still showing the same apparent knock issue, almost constantly. I’ve checked the ground connections, rechecked the ECU wiring, and everything seems to be in order.
Last week, I tested the car with a new tuner (specialized in Audi and BMW), not the one who mapped the car. While monitoring the engine using knock detection headphones during a 10 km drive, he confirmed that the engine does not have a mechanical knock issue. We also tried replacing both knock sensors with spares from the shop, but the ECU is still detecting knock on Knock Level channel
Now that I know it’s not mechanical knock, and having rechecked all the wiring to the ECU, I can’t figure out what might have happened at minute 51:35 of the first log session. Any help would be greatly appreciated. I’d like to understand whether other values also started to behave abnormally at the same time as the knock signal, or whether it could be an electrical issue, or something else entirely. What’s certain is that for the first 50 minutes, the logs looked perfectly fine — then something changed.
Any help would be really appreciated, thanks
Attached are:
the log from the session where knock started showing up at minute 51:35 - https://drive.google.com/file/d/1I-sz1HygPuhlxQJ1QF3crIWDLdxadMks/view?usp=sharing
the log from last week’s test drive while the tuner listened with headphones and confirmed there was no knock - https://drive.google.com/file/d/1tozK_l6Rn32p6mlxd6DyHXTNQGvzbq7R/view?usp=sharing
