M50 M54 knock sensor settings
Hey, if you have M50 or M54 working knock sensor, can you share your settings and log file of pull, I want to confirm that there is no problem with engine or just need decrease sensitivity. Weird that there is Hauge differences between cylinders.
My build fully forged m50b32, having noisy knocks signals with low and high frequency and 3 degree timing.
Shielded wiring
New bosch sensors
my setting
High freq.
Here is low freq. just revving engine
Solved by setting integrator to 200-210, verified actual knocks on dyno.
Thanks for sharing these settings @ELMEPRO. I made a log using these and it seems to detecting kock, could you or somone else have a look and tell me if these are actual knocks and thats how the log supposed to look like.
They seem to be consisten around 3k RPM 140kPa where my ignition is set quite high at 24
**(m50b30 turbo forged internals )
It is easy to verify. Retard ignition by for example 10 degs and make another pull.
If the spikes dissapear then this virbation is mechanical stuff not a knock
You mean: if spike is still there then you can revert your ignition angle to 24 and you are sure that spike was not produced by detonation but because of vibration - or?
