Main relay control
is there any possibility to control an custom output over the Keypad as ignition on in emu pro (emu pro has also only battery and should get igniton + over this
thanks
EMU PRO is completely turned off if no “+12V switched” signal is present. This signal must be provided from an external switch/relay/PDM.
If you want to kill the engine with the keypad, use an output from EMU with a relay to disable the power to the injectors/coils. Or maybe you could use the start/stop strategy. To help you better, I need more information about your setup and what you want to do precisely.
Hi, i will send you everything this evening. I will work there on the weekend again
