hi there,
is there any knob similar to the foto to work with the pmus for exemple? that can make a lot of functions, like blinkers, light, wipers, etc?
digital or canbus version is preffered.
for me this is the easy way to control a car.
I don’t know of any aftermarket levers like that.
The easiest is to use the OEM lever from the car.
If it’s a lever with all mechanical switches, you can connect it to PMU. There are no special requirements.
If it’s over the CAN bus, you need some documentation or do reverse engineering of CAN data.
I used a CANchecked MCE18
Ran all the individual funtions through its digital and analogue inputs and sent the data over can to the PMU24
You could as mentioned above if its a mechanical switch wire the 5v of the PMU to the supply pin then each of the analogue inputs to the other side of the individual switches.
It depends how far away your PMU is from the switches and how far you want to run cables
