My car has a gearchange system that activates the up/downshifts by connecting a wire to ground when the paddles are pulled.
I’d like to use the PMU so i can send these signals through CAN from the steering wheel and out of the PMU.
Would i be right in thinking i would need to use the Autosport version of the PMU which has low side outputs to connect the 2 wires to ground when the paddles are pulled?
