New ADU software version 108.0.1-exp
We’re pleased to announce the release of the new experimental ADU software version 108.0.1-exp! This update brings improvements and fixes.
New features:
  • Added support for J1939 Active Diagnostic Trouble Codes (DM1)
  • Project Tree: Introduced a new “Rate of Change” operation for the Number element, which calculates the derivative of a given channel
  • Added “Master Brightness Channel” option to the CANbus Keyboard settings
For full details, check out the changelog. Download ADU software version 108.0.1-exp today!
http://www.ecumaster.com/testVersions.html
new Rate of Change operation sounds cool.
Later down the line would it be possible to add moving AVG or time AVG to the number element? Over 1s 5s 15s etc?
sometimes the current value changes too fast to much. Reducing display frequency is not the same thing, obviously.
Thanks!
Thanks for sharing your idea!
We will think about the feasibility of this idea as, at this point, we are running out of memory in ADU, but maybe adding some simple filter will be possible in the future. However, I can’t provide you with any promises or a timeline regarding if and when it will be done, but we will certainly consider your idea.
With the inclusion of the Rate of Change, would it be possible to build a generic PID process? I’m thinking a maths channel function where we input a sensor channel and a target channel/constant and it outputs a 0-100% duty cycle coefficient.
Is it possible to add a bitfield as a data type in the user canbus export options?
We have a plan to improve CANbus export in the next few months, so yes – it will be natively supported then.
However, at this moment you can achieve this using the project tree and send it through CANbus export. It will consume a few operations, but it is possible.
Feel free to write me an email (maciej.fudala@ecumaster.com) or send a DM here on the forum – I will try to help you.
Is possoble now with N numbers . Given status multpply by bit nuber (in decimal)
