New ADU software version 120.1-beta
New ADU software version 120.1-beta is now available.
This update is focused solely on bug fixes.
What’s new:
  • Loading project: Channels that reference a single bit of a user-defined bitfield (an Enumeration element marked as Bitfield) are now loaded correctly from a file.
    This fixes a bug introduced in Client version 120.0.
  • Other minor fixes
Download the update here: https://www.ecumaster.com/tv
Sincerely,
The Ecumaster Team
Wow, quick turnaround. Thanks.
tested yesterday, works fine
I updated to 120.1 and all my assigned buttons got deleted, not sure if this is a bug.
Also I was on track yesterday and I’ve noticed some of my sessions don’t contain any GPS data?
Cheers
Regarding the buttons: no, button assignments should not change after the upgrade.
From which firmware version did you upgrade to 120.1?
Could you share your project saved on the firmware version before the upgrade? I’m not able to reproduce your issue.
About the second issue – please share your logs.
I upgraded from 108.1 to 120.1
20250501_0819_10.adu (67.6 KB)
My data log is more than 8mb so can’t upload, please advise on how to share.
We’ve identified the issue with disappearing button assignments and will fix it soon.
Regarding the lack of GPS data in your logs:
  1. Please send the logs to me via email: maciej.fudala@ecumaster.com
  2. In your DM screenshot, we can see two sessions — one with proper data and one with missing data. Were both logs recorded using the same firmware version, or did you upgrade the firmware between those sessions?
Yes both sessions were recorded on the same software, I only came into the pits for engine checks and went back out on track.
I will email logs today.
Regards
Wayne
