New Data Master software version 2025.4 is now available.
What’s new:
- Support for decimal places and units from ADU user-defined elements
- Proper display of enumerations and bitfields from ADU logs in the Graph Log
Note: Both features require logs created with ADU firmware version 120.0 or later.
New ADU software version 120.0-beta
Download the update here: Ecumaster Data Master
Sincerely,
The Ecumaster Team
when I open more than 1 ADU FW120 logs, it 100% crashes. 1 log open works fine
Hi, thanks for the report. Could you please share the logs that are causing the crash? We’ve tested multiple logs recorded with ADU firmware 120.0 and haven’t encountered this issue so far, so having your files would help us reproduce and fix it.
20250507_1511_47.adulog (310 KB)
20250507_1239_58.adulog (416 KB)
2 small files, bike just running idle
thanks
it might not be related to FW120, as I loaded RC111, and it crashed on the second file as well.
The issue is probably with 2025.4 beta, as I don’t remember this happening in 2025.3 or 2025.1.
Thank you for reporting and supplying the logs @LSL1337.
Fixed version is already available: New Data Master software version 2025.4.1
