New eDash version 1.0.2 is available now!
iOS 16.1 or later (TestFlight)
Join the eDash beta β TestFlight -
Android 11 or later (Google Play testing)
Download eDash from Google Play
eDash can also be installed on Android 9 and 10, but these versions are not officially supported. Official support starts from Android 11. On older Android versions, we cannot guarantee that the app will work correctly, and some features may not be available.
For the best performance, we recommend that EDL-1 users update to EDL Firmware 1.32.
All important links, firmware updates, and documentation can be found in the Start Here post.
Whatβs New in This Build
Data Display
- Improved how the app receives data from the ECU. Data is now displayed faster and more smoothly, with less lag.
Bluetooth Connection
- Improved automatic Bluetooth reconnection. When the app is open on the screen, it keeps looking for the saved Bluetooth module and reconnects when the module becomes available.
Layout Editing
- Improved background image fitting. The image now keeps its original proportions, fills the entire grid, stays centered, and is cropped where necessary.
Stability and Interface
- Fixed several small problems with the interface, screen rotation, icons, and text.
- Fixed the most common causes of app crashes.
For the full list of changes, see the eDash changelog.
Thank you for your feedback β it helps us continue improving eDash.
Sincerely,
The ECUMaster Team
