Welcome to the eDash Open Beta testing group. eDash is currently in Open Beta, which means the application is still being actively developed and improved. During this phase, some features may change and occasional issues may occur.
We warmly invite you to test the app and share your feedback – your input helps us improve eDash faster and ensure the best possible user experience.
Android 11 or later (Google Play testing) https://play.google.com/store/apps/details?id=com.ecumaster.eDash
eDash can also be installed on Android 9 and 10, but these versions are not officially supported. Official support starts from Android 11. On older Android versions, we cannot guarantee that the app will work correctly, and some features may not be available.
• phone model
• OS version
• ECU type
• firmware version
• short description of the issue
• steps to reproduce
• screenshot or screen recording (if possible)
Save the resulting firmware .bin file to the root directory of an SDHC card.
Insert the card into the EDL-1 SD slot.
The upgrade process will start automatically. During the upgrade procedure, the LED will flash.
We have noticed that some BT modules used in EDL units have limited signal strength, which may require placing them closer to the installed tablet.
The maximum radiated signal level is emitted in the direction of the EDL device connector.
Awesome work on the app guys! After using it for a bit, I just have a few thoughts/ideas. I’m sure some others have had similar comments.
Allow removing widget name. Not all displays need a name, e.g. Battery Voltage.
Allow sizes larger than 6x6. Especially useful for smaller displays.
Add square gauge sizes. Can be used for Gear display with no gauge title (just the number in a square).
Allow removing gauge border (for use with custom gauge background, so just the needle basically).
Add output flag lights (e.g. light when fans are active, nitrous is armed, or water pump is on). Don’t think these are on the CAN stream but would be nice to have.
Allow removing gauge/display units like V, C, etc.
Allow changing display units for the particular gauge.
Additional options/functions that would be nice: Odometer, Trip, Calculated Fuel Level channel + refilling function.
Is there any timeline for two-way communication with this setup? (Black + BT module)
I was going to try this on my Android head unit, which has both USB and CAN connections, which would be lovely if they could be used rather than only Bluetooth, so I’ll second that suggestion
I second the another connection option. I use ftdi rs232 USB converter in my car. Would be great if the edash would support this interface, because Real dash currently does.
Is there any plans of supporting android auto or apple car play? Would be awesome if I could just use any head unit with CarPlay and display it on there!
No, unfortunately we don’t have plans to support eDash on Android Auto or Apple CarPlay. As far as I know, it’s currently not technically feasible — but it’s on our ideas list and we will analyze it more deeply.
Anyway to get Just the APK and not the XAPK?
Will this work with an Android 10.0 double din?
Since I upgraded to V3 my old EMU Dash app that i use no longer works, which its discontinued yes but it’s the only app that actually works with my EMU EDL-1 datalogger, I’ve tried Realdash with no luck and also TunerView with no luck.
Sidenote Is there a Guide/How-To for this to work on IOS? I’ve downloaded it on my iphone 17 but can’t seem to figure out how to get it to connect to my EDL-1. (yes bluetooth enabled to scan for the EDL, I’m assuming it has to pair with my iphone first similar to how it’s done with Realdash pair with android device first then it will show up, but the EDL-1 don’t show up under my bluetooth connections).
That must have been a new update becasue I downloaded on the 25th of May and the latest version available for DL was v1.26.
Will update to V1.27 and see what changes
Would still be nice to get an eDash version That works with Android double din running Android 10.0 and an APK download for That. The idea of buying a new doubledin when I already have a working one just for to see dash parameters again is tough.
The other Issue I’m faced with is I have iphone 17 and I also can’t use the app with my phone for some reason as My EMU Black is not the USB-C version but the Micro version… Lots of hurdles being faced currently.
This has nothing to do with the USB connector type on the EMU Black, so I’m not sure where that information came from.
Could you please describe the connection issue in more detail?
A few questions that will help:
Are you using an EDL-1 Bluetooth module?
Is the EDL-1 visible in the device list inside the eDash app?
Have you tried connecting to the same EDL-1 using an Android device? If so, does it work there?
This information will help us determine whether the issue is related to Bluetooth communication, device discovery, or something else.
Cannot get the bluetooth to connect on any device I’ve tried. Updated the EDL-1 firmware to the latest via SD card.
It is wired the old way with 1 serial communication wire, may add the other in the future.
Following the setup guide kinda makes it seem like we are supposed to find the device in the app. Phone doesn’t see the EDL-1 in app or in the settings.
EDL-1 has power and ground, blue light is slow flashing. Logs to SD card just fine.
Not sure if I have a different issue then a software mismatch, but not sure what to try. Can’t get eDash on IOS anymore that I know of…
Edit: tried every EDL firmware with no change, tried V3 and back to V2 on 2.178 with no change. This EDL-1 is around 6 years old, suspect it might be the older BT chip. My laptop can see the device but not iphone’s (oldest one we tried was a 11 mini)
I believe this is related to the fact that iOS has limited to zero Bluetooth SPP support. From all the reading I’ve been doing, the older EDL1 devices only have SPP. The newer ones have BLE, which iOS does support. I wish Ecumaster was a bit clearer about this whole thing. There are a lot of different models with different protocols that are or are not compatible with lots of different devices.
