New EMU PRO software version 115.2-exp
We’re announcing the new EMU PRO 115.2 experimental software update.
This release addresses issues found in version 115.0, bringing essential fixes:
  • Synced H-bridges now initialize correctly
  • Improved trailing spark angle precision for Porsche 129/132 and BMW 116 primary triggers
Additionally, this update includes minor client software improvements:
  • Resolved Z-axis channel corruption when using custom user channels
  • Improved stability for Graph Log
Download the EMU PRO 115.2 experimental today and test it out! Share your feedback.
Download Link: https://www.ecumaster.com/testVersions.html
Sincerely,
The Ecumaster Team
You have reduced user memory (115.x) from what was avail. in 110.x? Like… 5%?
Cant load the project anymore, as it says memory limit exceed (100,51%)
I have lots of CAN stuff and functions and, yes I can delete some stuff (ie. gps stuff now) to go below 100% again, but you should be careful about limiting user mem. too much.
We didn’t lower the memory pool.
We added new strategies that are using part of that memory pool.
You can minimize the size of tables you are not using to regain some of the memory.
Since it’s another situation where users hit maximum memory, we will try to do something about it.
Thanks.
Making some unused tables to scalar dont help much, and it´s not very user friendly way as you need to open every menu to find out what you can minimize and what you may need in future. Can frames and functions are those that are using most of my memory so I´ll focus on those as an easy solution.
Same situation here, on fw111 has 97,8% , when load in 115.2 getting error memory exeeded 101,3% .
Using multiple 4D maps, so not happy that i must sacrifice some…
Sorry guys for all the inconvenience.
In the next build, we will add more memory to compensate our latest changes.
Fortunately, we have some spare memory.
That would be nice.
I just upgraded my other project firmware to latest, witch was made with 99.0, and memory usage went up over 10%.
If you need to cut user memory in future, please add that in patch notes :slight_smile:
Thank you very much for reporting. We did not know about the problem until your first post here. We will add 10% to the next build.
We will also work to make the user memory fixed in size and not be the “rest of”. So even small changes in the core functionality will not affect your work.
Thank you
GPS to CAN: There´s no GPS speed in logged channels?
You’re right @SamiN. It will be added in version 116.0.
Hi guys!
We’ve released the 116.2 firmware with two improvements mentioned in this thread:
  • added 10% more memory for user content
  • added GPS Speed channel
Thanks,
Appreciate the update , that was for the software update I asked for…
