New EMU PRO software version 225.1 Public Release
We are pleased to announce the public release of EMU PRO software version 225.1. This update includes multiple new features and enhancements compared to the previous official version 216.1.1.
Firmware version 225.1 includes a stability improvement, fixing a rare issue affecting some EMU PRO units.
New features:
  • Added injector preset system with calibration data for seven direct injectors measured by Ecumaster.
  • Logging presets can now be exported and imported, making it easier to transfer logging frequencies between projects.
  • Improved startup behavior for direct injection engines (requires GDI Driver firmware version 4.0).
  • Added closed-loop mode for Custom Stepper Motor control.
  • Added support for Mini R56 N14 PWM high-pressure fuel pump.
  • Added support for BMW EKP E90 fuel pump.
  • Improved nitrous strategy.
  • Improved overrun strategy.
  • Automatic planetary gearbox: added support for torque reduction and throttle blip.
  • Added new sensors: Cylinder Head Temperature and Wastegate Temperature.
  • Added support for user-defined names for Custom Switches and Custom Outputs.
  • Added support for copying and pasting table data to and from Excel (and other spreadsheets).
OEM CAN Streams:
  • Added Subaru Impreza III (GH) Stream
  • Extended BMW E90/Mini R56 Stream
  • Improved VW PQ35 Stream
  • Improved VW MQB Stream
New triggers support:
  • Renault 5 - 2*(22-2)
  • Signal Level
  • Gap Detection option for engines with a high compression ratio
New LIN protocols:
  • Pierburg CWA400 Water Pump
  • Ford Fiesta Wipers
  • Toyota Supra MK5 Wipers
  • Bosch WDA Wipers
New automatic gearboxes:
  • GM 4L60E
  • GM 4L80E
New GDI engines base maps available:
Download the latest software update and explore these new features:
https://www.ecumaster.com/products/emu-pro/
For more details and full list of changes, see the changelog.
We appreciate your feedback — it helps us make EMU PRO even better.
Share your thoughts and suggestions to help shape future updates.
Sincerely,
The Ecumaster Team
Nice
Fixes: • Resolved a rare stability issue that, in specific conditions, could result in an ECU restart.
I actually noticed that about 3 times within 15000km I’ve covered. Very annoying given the DSG won’t let me restart on the fly - engine torque just disappears and I have to move my shifter and stop.
Still have no reliable steps to reproduce so never posted. Just wanted to ask about the RESET CAUSE - mine were logged as WDT afaik. Could you update the description?
Also CWA400 not 500 (only in the post. correct everywhere else)
Yes, that’s the same exact problem.
Two questions: Pro 8 or Pro 16 - and are you logging to a USB flash drive?
Pro8 on the car I’m talking about. Logging always yes.
Pro16 on another and logging but it’s not being driven much and it’s used as a secondary ECU. Haven’t had the issue yet
Maybe i met something similar with unstable USB logging(its just stoped and not start again until engine restart, pc client logged no problem at same time). Maybe this update will help.
But im just here to ask, is it somehow possible to jump between Graph log tabs? When i have several of it, on smaller laptop starts some be hidden on right side and i cannot reach them until rearange layout of whole screen.
And two small things:
The BLACK can stream is transmited only 20hz, on Black ecu is 25hz is i remmember right.
When i connect VW Hitachi MAF sensor , it gives 0.58khz at zero flow, and MAF sensor setup option has minimum limit 1khz, so it throwing error.
Thank you for confirming. We were able to reproduce it only on this exact setup.
I think the fix will not affect USB logging. Check our technote about logging to USB in EMU PRO.
What brand of USB flashdrive are you using?
We will check.
Good to know. I’m not sure if we can lower the minimum limit. I’ve recorded a change request.
USB is sandisk ultra fit, it works on dyno and first race, on second race issue begins, didnt find anything wrong(connection…), stationary revving no issue. Will see in future.
What about my question moving between graph tabs?
And will be anytime soon ability of comparing differences between two projects?
thanks
SanDisk is a very good brand.
The two possible causes are vibration and electromagnetic interference.
If the issue occurs again, please record a log using a laptop if possible (yes, from a laptop – we will be able to see everything on one datalog).
You said that after a power-cycle it started to work again, which is a bit strange.
Yes. It’s one of our top priorities for UI. It will be available in the next few months.
Yeah, I know what you mean. Small bug, but very annoying. We’ll try to make it happen in the near future.
Is there any plan to update the help for Emu Pro software, there are a lot of parms described as “This is a variable”, “This is a table“ or “This is a group” etc without any clear explanation on how those can be used and how are they going to affect the calibration.
Before anyone asks if I have any specific issue I will say that I don’t have but when trying to debug something or implement something I often come to the conclusion that the documentation inside the soft is poor.
I even have the feeling that Emu Black V3 software is better documented that the Emu Pro software :exploding_head:
Thanks for the feedback — we’re actively working on improving this while balancing ongoing development.
During development, we were heavily focused on adding new features, which unfortunately left parts of the documentation behind. Since last year, we’ve made it a rule that every new feature is delivered with proper documentation.
We’re now working through the backlog of undocumented items. In fact, the upcoming beta already includes descriptions for over 300 parameters.
