New EMU PRO software version 222.0 beta
Updated EMU PRO software version 222.0-beta is now available.
What’s new:
  • Added option to select whether Fuel Rail 1 or Fuel Rail 2 is used during cranking
  • LIN Wipers added (Ford Fiesta, Toyota Supra MK5, Bosch WDA)
  • LIN Water pump added (Pierburg CWA400)
  • Added new Gap Detection options in Trigger Primary for engines with a high compression ratio
  • Added initialization state for Throttle Position Sensor diagnostics when a SENT-over-CAN sensor is configured. This gives the GDI driver a 2-second startup window to start sending SENT data.
  • DBW Tuner now supports throttle position sensors with an inverted (falling) main signal characteristic.
  • Improved DBW Tuner compatibility with throttle bodies where the limp position is 0%.
For the full list of changes, check out the changelog.
Download EMU PRO software version 222.0-beta today! http://www.ecumaster.com/testVersions.html
Sincerely,
The Ecumaster Team
Rail 2 cranking works perfect, thank you!! Should have this Gen 3 coyote on the dyno tomorrow, I’ll get the cams all dialed in and send over all the DI setup. Thank you for the support!!
I think I have found a usb stick logging issue, possibly similar to the 216.1 beta.
I spent an entire day trying to get logs from a test session, was getting broken logs. It would record for a minute or two, then nothing for a few, then 2-12 seconds, then not etc.
Also had 2 separate instances of it filling the USB drive with “USB-C” files, same amount as logs. They wouldn’t come off the drive and only way to get rid of them was formatting or delete all and ejecting.
Confirmed the wiring (shielded), tried a few usb sticks, formatted them again, moved the usb stick to a cooler area etc. Nothing worked, downgraded to 220.1 and it worked as it should again.
I’d rather not publish my serial number but I’ll DM/Email a dev who wants to see the logs.
We did not touch the USB logger code between 220.1 and 222.0.
Please send us your logs to jan.matlag@ecumaster.com, and we will investigate the issue.
Thank you very much
