Hi everyone,
I’m reaching out because I have a lot of trouble to resolve this problem.
Here is the context :
A tune shop install an EcuMaster EMU Black on my Nissan 350Z (VQ35DE with HKS supercharger) with lambda sensor.
They made a tune and the car made 350 HP on E85.
But when they handed me over the car, the throttle felt really strange :
The throttle pedal have a deadzone of 10% approximately => The TPS register my inputs well (I can see it moving from 1% to 100%) but the engine RPM doesn’t move if I’m staying in the 1%-10% zone.
When I’m blipping the throttle during a downshift, the engine take a lot of time to respond, I’ve made a log file of me driving around with a few blipping during downshift. The engine RPM “hesitate” and then rise.
After blipping the throttle, the RPM drop below the idle target and goes back up.
I tried to re-calibrate the TPS but it doesn’t change the behavior.
I try to rise the throttle speed limit to 1500 %/s, the throttle felt a little better but that was not enough, I feel the same hesitation from the engine when blipping.
I rise the idle range to 7 in order to solve the third problem and it works pretty well.
You can find below the tune that is applied to the ECU and the log file mentioned earlier.
Tune :
Log :
Did you have seen something like that before ?
I’m on the 2.175 client version, Variables CRC = 1EA9 and Tables CRC = 136.
