So car was fine last month. Been busy so not touched it. Came to it today and it’s not working. PMU is say output is switched LED is on but getting no voltage out of it? Current jumps up But 0 volts ???
Any ideas please
Did you unselect that in the logger? If you did, live data will not be shown.
Not sure what you mean. I can watch the inputs on the screen. See me turn on the output. Current on output changes but voltage stays at Zero volts
Which channel should we be looking at?
The “emulated” makes me think you’re using the output emulator to turn on the output? or how are you turning on the output?
