Prime fuel pump when ecu is turned on?
Hello
ecumaster pmu 24,motec m400
im receiving information via can bus from m400 i can get the fuel pumps to run by rpm true function
but id like to prime the fuel lines on ecu power up for 5secs how would i do this with out using the fuel pump aux out from ecu wired into input of pmu ?
Pulse option and and condition “or”
function you are using now
