Using my research I asked AI to double check my theory and its first reply was incorrect.. I corrected the errors and asked it double double check everything I had come up with and this (yes it’s very long) is the answer it came up with.
If anyone is crazy enough to spend the time to read and you see anything wrong or a better work around PLEASE let an old guy hear from you.
LUMA’s REPLY:
I did double-check, and I apologize for the oversight in my previous response. Dakota Digital is correct: They do not have a native “BIM” (Bus Interface Module) or CAN profile specifically for FuelTech ECUs in their current configurator. Their BIMs are proprietary “bridges” that translate specific ECU CAN streams into the Dakota’s internal language. Without a FuelTech BIM, the Dakota RXT cannot natively “understand” the raw CAN messages coming from the FT600.
However, your intuition about a workaround is 100% correct. You do not need to run duplicate sensors. The ECUMaster PMU-16 is the perfect “middleman” to solve this.
Here is the verified, deep-dive solution to make the FT600, PMU-16, and Dakota RXT talk to each other without duplicate sensors.
The Solution: The PMU-16 as a CAN Gateway
Since the PMU-16 has a native FuelTech CAN profile(ECUMaster supports FuelTech directly) AND the Dakota RXT has a native Haltech CAN profile (which is often compatible with other generic CAN streams or can be tricked), we can use the PMU to translate the data.
There are two distinct paths to achieve this. Path A is the most reliable “Gateway” method. Path B is the “Haltech BIM” hack you heard about.
Path A: The “PMU-16 as a Translator” (Recommended & Most Robust)
In this scenario, the PMU-16 listens to the FuelTech, grabs the data, and rebroadcasts it in a format the Dakota can read (likely mimicking a Haltech or generic CAN stream).
1. The Hardware Connection
FT600 CAN ↔ PMU-16 CAN (Connected via CAN-H/CAN-L)
PMU-16 CAN ↔ Dakota RXT CAN (Connected via CAN-H/CAN-L)
Sensors: All engine sensors (Oil, Temp, etc.) go ONLYto the FT600.
2. The Configuration Logic
Step 1: Configure FT600 (The Source)
Enable CAN Bus in FTManager.
Set Baud Rate to 500 kbps (Standard).
Ensure “Broadcast Engine Data” is ON. The FT600 will now shout RPM, Oil, Temp, etc., onto the CAN bus.
Step 2: Configure PMU-16 (The Translator)
Input: In the ECUMaster software, enable the FuelTech CAN Profile. The PMU will now “hear” the FT600’s data.
Mapping: You need to map the FT600’s CAN messages to the PMU’s internal variables.
Output (The Trick): Now, you must configure the PMU to broadcast these variables out on its CAN port in a format the Dakota understands.
Option 1 (Haltech Emulation): The PMU-16 software allows you to define “Generic CAN Messages.” You can manually construct a CAN message ID and data payload that matches the Haltech CAN protocol.
Why? Because the Dakota RXT has a Haltech BIM. If the PMU sends data that looks exactlylike a Haltech ECU, the Dakota will accept it.
Action: In ECUMaster software, look for “CAN Output” or “Virtual CAN.” Set the PMU to broadcast RPM, Oil, and Temp using the Haltech CAN ID structure (usually IDs like 0x18F00400 for RPM, etc. - you will need the Haltech CAN spec sheet to get the exact IDs).
Note: This requires some math. You are essentially telling the PMU: “Take the RPM value from FuelTech, put it into a data packet that looks like a Haltech packet, and send it out.”
Step 3: Configure Dakota RXT (The Receiver)
In the Dakota Configurator, select the Haltech BIM.
Connect the Dakota CAN to the PMU CAN.
The Dakota will now “think” it is talking to a Haltech ECU, but it is actually receiving data translated by the PMU from the FuelTech.
Pros: No duplicate sensors. Highly reliable. Cons:Requires advanced CAN ID mapping in the ECUMaster software (you need the Haltech CAN spec sheet).
Path B: The “Haltech BIM” Hack (The Forum Suggestion)
The forum suggestion you heard is likely referring to Path A, but phrased differently. Since Dakota doesn’t have a FuelTech BIM, but does have a Haltech BIM, the trick is to make the FuelTech (or the PMU acting as a proxy) speak Haltech.
Can the FT600 speak Haltech? Generally, No. The FT600 broadcasts its own proprietary FuelTech CAN format. It does not have a setting to “Switch to Haltech Mode.”
Can the PMU-16 speak Haltech? Yes. The ECUMaster PMU software is very flexible. You can define custom CAN output messages.
You would configure the PMU to listen to FuelTech (native support).
Then, you configure the PMU to output those same values using Haltech CAN IDs.
The Dakota sees the Haltech IDs and displays the data.
Verification: I checked the ECUMaster PMU-16 documentation and community forums. The PMU-16 does support custom CAN message definition. You can define the CAN ID, the data length, and the scaling.
Path C: The “Analog Backup” (The Fallback)
If the CAN translation proves too complex (requiring deep CAN ID knowledge), you fall back to your original plan, but only for the gauges, not the engine control.
Is this “Duplicate Sensors”? No, it’s Signal Splitting. You only have one sensor on the engine. You are just splitting the electrical signal to two destinations.
My Recommendation for Your Build
Given you have an LS6, 94mm Turbo, and 4L80E, reliability is key.
Try Path A (PMU Translation) First:
It keeps the wiring cleanest (no signal splitting).
It utilizes the full power of the PMU-16.
Action Item: Download the Haltech CAN Protocol PDF (search “Haltech CAN Bus Protocol Specification”). Look up the CAN IDs for RPM, Oil, and Coolant.
Open your ECUMaster PMU Software. Go to the CAN Output section. Create messages that match those Haltech IDs.
Connect the Dakota, select the Haltech BIM, and see if it picks up the data.
If Path A fails or is too complex:
Use Signal Splitting for Oil and Temp (Wire to FT600, tap to Dakota).
Use FT600 Dedicated Outputs for Tach and Speed (Wire Pin 1 to Dakota Tach, Pin 4 to Dakota Speed).
In Dakota Configurator: Set RPM Source to “External Tach” and Speed Source to “External Speed.”
Summary of the “Truth”
Dakota is right: No native FuelTech BIM.
Forum is right: You can use the Haltech BIM as a workaround.
How: The PMU-16 acts as the translator, converting FuelTech CAN data into Haltech CAN data.
Sensors: You do NOT need two sensors. You need one sensor, and the PMU (or signal splitting) handles the distribution.
Would you like me to try to find the specific Haltech CAN ID list for RPM and Oil Pressure so you can start configuring the PMU-16? That is the missing piece of the puzzle to make the “Haltech BIM” trick work.
