Problem with idle on cold start
I have a 2014 Lancer turbo with EMU Black installed. The problem I’m having is that when I start the car in the mornings, the idle is erratic. The RPMs fluctuate until it reaches normal operating temperature.
I’ve adjusted the fuel mixture to try and correct it, but the problem persists. I’ve adjusted it up to 24%, but the idle is still erratic. Any suggestions that might help with this problem would be greatly appreciated. Thank you.
Please excuse my English.
Several settings influence idle behavior, and any of them can cause an unstable idle. The best solution is to attach a log file along with the EMU Black settings at the beginning, so we have a solid base to work from.
Hello im gonna send you the file so you can check it out i hope you can solved the problem thanks you very much.
(attachments)
Michael rivera tune.emub (143 KB)
Usually u should also send a log to identify the problem, but according ur settings it is clear that there will happen strange things in idle.
Ur idle ref table makes no sense, ur idle air PID settings are not good and ur VE table also seems to be wrong. All three tables need a base tuning and ur problem will be solved.
