R53 EMU Black - Fuel Cut issues
Hi all. New to the forum and am currently configuring the base map for an R53.
Got the car running at reasonable idle, however, whenever I go to rev the engine, I can physically see the ECU apply fuel cut very shortly after the peddle is pressed, even lightly.
I cannot work out why this is - in previous ECUs there have been some sort of tags for why fuel cut was applied, but I am baffled here.
Looking through the log file, I can’t see anything which is jumping out, so looking for some help here.
I’ve included a screenshot.
Also adding the fuel cut parameters which are as per the base map.
Turned out this was in fact to do with Stuck Throttle Protection - the ECU was cutting fuel due to the STP registering. I’ve resolved by turning the option off for now.
For anyone ever looking for issues with fuel cut, the log section of the EMU has a table called FC Reason - this is where you can get the data.
Did you ever find a solution to this issue? My car is doing the exact same thing, had to turn STP off, but would like to have it as a safety feature.
Sadly not yet. Agreed, I’d rather have it on as well but it just doesnt seem to play well with the current version :frowning:
