Scatter Plots Trimming Data Off
How do you correct the scatter plot from trimming off data? When I plot TPS vs MAP, anything under about 9% TPS is trimming off.
Check your TPS min/max in the log channel configuration.
Scatter plot use it to limit scatter plot channels data range.
I tried that and looked at both TPS and MAP and both are set to 0 to 100 and the problem still exists. Is there a filter/setting somewhere else?
Could you please publish here a log ?
The log I am using is too big, but this log shows the same issue. There should be lots of data for TPS below 10% throttle. Also, I am on V2 V2.169 and the log file extension is .emublog. The post wouldn’t accept this so I changed it to .emub.
20240908_1718.emub (3.0 MB)
Thank you. I can confirm there is a problem.
It will be fixed for the next build.
Thanks. Roughly, how long will this take?
This week, as the issue is is already fixed
I am fairly new to EMU. How do I download the update to my current software? I am on V2 Ver 2.169.
The beta versions are at www.ecumaster.com/tv
The latest one is 2.170
There is a new version 2.171 where the scatter plots are fixed.
Thank you! I checked it and all looks good.
