Attempting to set up a 10 Bar back pressure sensor for my turbo. I notice there is a back pressure calibration available but for some reason, its set for only 115 psi max. Not sure if there is an alternative way to set a senor up separately from the preset sensors available?
Ooo I have a post about this somewhere, though it was in regards to coolant pressure the same trick works.
You need to find (using math) the voltage at 115 psi, then enter that in the table. The calibration will just extrapolate past the max table value.
See this spreadsheet I made for it, download your own copy so you can edit away.
Math tells me if you change the table to this it’ll be calibrated:
Awesome! I appreciate the response. Thats a very useful spread sheet as well.
