Hi all,
I purchased a car running Ecumaster black. It was tuned, and only recently have I connected a laptop to it. I’ve found two things - first the TPS sensor is set max at 5v, but the sensor only wide open only gets to much less - hence max reading is 64%. The second is the map is reading 105kPa when engine is off, which high seems high.
I don’t want to correct these sensors as I’m worried it could affect the tune and I’m not knowledgeable enough to be confident. The car seemed to run fine before (currently having an issue with my spark plugs as they got some water in them). Is anybody able to share any light on what checks I should do before correcting these sensor readings?
