So using v3 software on by black. I’ve bought a syltech oil pressure/temp sensor. Having a bit of a hard time getting to read anywhere near what temps it should be. Using the ecu master sensor wizard the preset data dosent seem to quite match the sensor specs, I can alter that, but I’m still way off. I tried a 330 ohm resistor wired in and the temp just shot straight up. So I’ve now removed, played with the internal pull-ups but still can’t get it quite right.
Any ideas fellas?
