Short Term Trim Correction
Hi
Have sometimes under WOT Conditions that the Fuel Short Trim is not responsive.
As Example Lambda Target 0.77 and I have 0.719 → Short Term Trim 100%
So my Question is where should I look first…Lambda Delay or P and I Correction?
First u set lam delays correctly by taking different exhaust flow points, steady state and then digitally change lam target without shortermtrim active and measure the lam responses and fill the table.
Then u tune P portion…then I portion like in every other PID.
Increase the values till it starts to osciallate. This is then the max value u should set.
You can use debug - pid - shortTrim log a file and open Debug PID channels for each of them.Then you can see exaclty how the controller acts
Good Points will try booth
Have looked in the log. Where I find these debug PID? Have found general Debug P, I,D but that shows nothing
Its in tab “others” and then “debug functions” and chose “shortTrim” and then make a log again and you Will see the controler at logs
What are some typical setting for short term trim? Standard they are somewhere around 3% and 5%, I think. I’ve gone all the way up to 40% (P) in order to get a decent response. What are others doing?
Any replies/thoughts about this? What is “typical”-ish?
Bumping for any replies
I have P arround 60%
Thanks. That does help.
Until a couple of weeks ago I was trying to get these setup somewhere around the default range of 4 and 8 (or something small like that). Generally, PID doesn’t need a ton to be responsive, but at those low settings it was just slow as heck so I was confused by it. I recently spent an hour or so just driving and changing, driving and changing - watching data logs - and ended up in the P=45 and I=15 range, but it’s still not crazy accurate. It’s much more responsive, but has some behaviour that tells me it could be better. So, I’m just trying to get an idea what others have settled on.
I think u already somewhere had a look on my settings. I used this in V2:
The PID has limits. The higher the better, but if too high u see osciallations. If u reached the highest possible gains without landing in osciallations u reached all u could in ur PID. If u then want more accuracy then u should look for other stuff depending on the behaviour.
Hahaha… I freely admit, I did look at your settings.
I am still curious what others are running for PID and the g/s correction tables.
