Software crash while attempting to update firmware
Hi everyone,
I’m running version 3.032 due to my car being down for a while. I downloaded the latest beta however the software crashes immediately if laptop is connected to ECU.
I tried many beta versions with the same error.
Has someone had the same error as me and managed to fix it? Thanks! Crash logs are attached.
EcumasterEMUBLACK340_error_report_250723-181957.zip (692.0 KB)
EcumasterEMUBLACK353_error_report_250723-181649.zip (694.5 KB)
Hi, I had the same problem coming from 3.033 and solved it by updating firmware in steps. First to 3.035, then 3.040b, 3.051a and lastly 3.053a. Maybe you can skip version 3.051a and just go to the latest, but that worked for me. I think the problem is because the version that you and me were coming from was in alpha(and for that a special key was required for the software to work) and the newer versions are beta and dont use that key anymore
Thank you, this worked perfectly!
