Some logging channels can't be omitted from logging, or have their rate reduced
There are a number of logging channels I don’t need. I can’t seem to reduce their logging rate or stop logging them altogether.
Can’t remove, but can reduce rate, of:
  1. Boost pressure (I don’t have a turbo)
  2. Boost target pressure
Can’t remove and can’t reduce rate of:
  1. Lambda 3 below 25Hz (I only have two sensors; inline 6 with two 3:1 collectors)
  2. Lambda 4 below 25Hz
  3. Throttle 2 position below 25Hz (I only have a single TB)
  4. Volumetric efficiency Bank 2 below 25Hz
  5. Timing Intake camshaft 2 Position below 25Hz
  6. Timing Exhast camshaft 2 Position below 25Hz
There are probably others that I haven’t run into yet.
Yes there are more of them. Also is annoying that even non logged paramaters are still to choose in graphlog, its very messy then, but we can hope to be better someday…just it getting years unfortunately.
