Pro 8 sensor set up
Hi , I’m just setting up my pro 8 which is going well but having trouble with some sensors, for example oil pressure… the ecu can read the volts and Ive selected source and input and the volts are there but can’t seem to get an actual pressure reading just question mark. Hope you can help.
The question mark indicates that logging for that channel is disabled.
You have to set a logging frequency for that channel.
You can do that from the context menu (right click) or the logged channels panel (F8).
This channel should be logged by default.
Are you using some base map?
I would like to understand why the logging for that channel was disabled in the first place.
Hi there, thanks for getting back, I’m using analog 8 for oil pressure, when I try to select frequency it say too much data per log frame
That means you maxed out the logging bandwidth.
To enable logging for this channel, you have to remove or lower the frequency of a different channel.
You may want to check the document on data logging.
Honestly thank you it works perfectly now.
