Hi
I’m trying to start a customer’s EZ30 swap. At the beginning, I found that the crank trigger wheel was touching the sensor.
We replaced both the trigger wheel and the sensor, but I’m still having a synchronization issue.
It’s possible that the problem is related to the trigger settings in the ECU.
Does anyone happen to have a base map for the EZ30 that I can use as a starting point?
Thanks in advance,
Ofir
