Hey everyone,
I recently upgraded from ECU Master EMU Black V2 to V3 on my RB25DET Series 2 and I’m running into trigger synchronization issues. Before the upgrade, the car started and ran fine on V2, but after switching to V3, I’m only getting “Synchronizing” but not “Synchronized” in the trigger status. The car cranks but does not start.
Here’s my setup and what we’ve tested so far:
Setup Details:
• RB25DET Series 2 (Stock CAS Disk)
• Nissan Trigger
• Stock CAS (360-slot inner, 6-slot outer)
• Trigger Edge: Currently set to Falling (we suspect Rising might be needed)
• First Trigger Tooth: 8
• Trigger Angle: 50°
• Cam Sync Window Min: 4
• Cam Sync Window Max: 12
• 12V Power to CAS confirmed
• Steady cranking RPM at ~105 RPM
• Trigger log attached (Scope Data Available)
Symptoms & Issues:
- Cranking RPM is low (105 RPM)
• In V2, I had no issues with syncing.
• In V3, the engine cranks but won’t sync.
- Trigger Log Shows Signals, but No Sync
• Logged trigger scope shows a clean cam and crank signal, but the ECU won’t sync.
- Drive-by-Wire Issue Also Noted
• After switching to V3, the throttle doesn’t hum at key-on like it did in V2.
• Short to ground error appears when key is on, but disappears when applying throttle.
Steps We’ve Tried So Far:
Checked Wiring to CAS – All Good (12V, Ground, Signal)
Confirmed Trigger Settings – Matches V2 Config
Tried Cranking While Logging Trigger Scope
Tested Adjusting Cam Sync Window Min & Max
Confirmed No Physical CAS Damage
Tried Copying Over V2 Configuration to V3 Manually
Questions:
Does EMU Black V3 handle Nissan CAS signals differently from V2?
Should I switch from Falling Edge to Rising Edge on the Primary Trigger?
Would a PRP or AEM 24-1 CAS disc help eliminate potential issues with the stock Nissan optical disc?
Are there any trigger signal filtering or input delay settings in V3 that could help?
Could the low cranking RPM (105 RPM) be causing the sync issue?
