Tps load with mp correction
How do i on an emu pro, how do i get load to be throttle position and correction by manifold pressure
Manifold pressure is always used in air flow calculation.
Change the efficiency load to TPS under the Engine section. Your VE table will be based on throttle position, but manifold pressure will still apply the correction to the calculated air flow.
